Old 08-18-2014, 11:35 AM   #6 (permalink)
Baltothewolf
Furry Furfag
Baltothewolf's Avatar
Winsight - '00 Honda Insight
Miaderp - '95 Mazda Miata
90 day: 28.53 mpg (US)
Originally Posted by Old Mechanic View Post
Blade types don't need to be pulled. I prefer to leave everything as undisturbed as possible to prevent self induced additional problems.
Disconnect the positive cable and put a test light in line between the battery cable and battery. Light on you have a drain even can be faint (the light).
Pull fuses until the light goes off and the last fuse pulled is the circuit that is causing your problem, but keep pulling fuses until you have pulled them all, youcould have more thnaone problem.
Doesn't work in newer cars which have continuous drains.
regards
Mech
Well the car has an alarm so wouldn't that mess with it? I know it has a red LED that's on 24/7 on the dash whenever the battery is plugged in.
