Originally Posted by Daox
From all the testing I've seen, acceleration technique really doesn't matter that much. Its much more important to avoid brake use, keep your speed down on the highway, etc.
I generally accelerate at a moderate rate. I try to load the engine to ~80%. RPM doesn't matter much unless you're redlining every shift. If you want to go accelerate a bit faster, go for it. Typically, I shift most cars around 2500.
I completely agree! I'm no speed demon, I like to be safe as well as efficient, though I do wish trucks could get the same mileage as cars
