Old 08-18-2014, 08:02 PM   #17 (permalink)
SilverCrown9701
SilverCrown9701's Avatar
SilverCrown - '01 Toyota Camry LE
90 day: 35.32 mpg (US)
Originally Posted by davelobi View Post
You should be able to achieve a fair bit better than 30 mpg in that Corolla.
Learn more about DFCO and when your car is in/out of dfco. You can run along the back roads slowly getting up to 55 mph and coasting (in gear) back down to 45 then repeat the cycle over and over. Watch your mpg jump.
I drive almost exclusively stick shift cars so my automatic transmission advice is more limited to the dfco testing I have done than when to upshift on acceleration. I do however believe that accelerating too slowly will reduce, not increase, your economy. Get up into the highest gear at a reasonable pace and then do your cruising as slow (traffic allowing) as you can in the tallest gear without lugging the engine. I'd guess a good engine rpm for that 1.8L would be 17-18 hundred rpm. Hopefully that will keep you in the 45-50 mph range. Back roads (as opposed to the expressway) are really your friend for economy.
Welcome to the nut house. Strength in numbers!
EDIT: oops, my bad. I thought I read Corolla. The Camry is a fair bit heavier and the 2.2 will be a tad thirstier than the corollas 1.8. 30mpg isn't too bad but with information and the formation of new habits you will see an increase. Good luck.
I think that's what my problem has been was taking my time getting up to speed, after reading many different sites suggesting that slower is better but I guess they failed to mention not in this case.
My car is at 1,800 RPM at 50 MPH, 2,000 RPM at 55 MPH, and so on...
Haha, it's perfectly alright! The Corolla is just a "mini" Camry, so don't feel bad!
The name "Camry" is an Anglicized phonetic transcription of the Japanese word kanmuri meaning "crown".
