Old 08-18-2014, 11:23 PM   #1 (permalink)
charlesreekiejr@yahoo.com
air filter and oil
This is not the first caddie that I used the same combination and had similar results the 2000 escalade 5.7 also ran much better . So explain how it ,all three ran better no more misfires do you think everything works like you read or been told? Explain how if the computer adjusts for clean or dirty and it makes no difference. Do you believe it can truly compensate that well. It cant adjust for everything less turbulance is the key much like aero dynamics same principle . Yes i understand what your saying but you can not explain the gain I have with either and not done same time either. So you must think this is a lie or exageration because you cant comprehend or understand it. Well there are many things we can comprehend or understand they just are. There isnt a computer than can compensate for every aspect. Yes they all had more power. All ran with little or no missfires after . Missfires are direct influence on mpg as it is fuel unburned efficiently . Dont have logs im not into it like some just doing what works , you dont believe thats fine I dont care what you think this works for me if you have not tried this how can you disprove this , oh yea you read it somewhere that is someones opinion not fact. Explain why there are misfires before and now there is not ,you cant you cant substantiate it either.
