As was said it can adjust fuel to air ratio it can not change turbulent air flow.Any of these ring a bell path of least resistance straight line .And I am not the only one who gained mpgs from synthetic oil really you dont comprehend less friction less heat less fuel used to do the same amount of work. Any restriction is a problem that can create turbulence. Do you believe simple mods cant increase mpg oem does it better no it is mass production and cost control. What would happen if you could atomize fuel into a smaller particulate size and better the air fuel mix well you would get a better burn. Ok picture an oil furnace nozzle thats dirty it spits does not atomize properly therefore requires more fuel to generate more heat carbon form from the incomplete burn do some research take the blinders off.
