Old 08-19-2014, 01:00 PM   #1 (permalink)
accord_minded
Is this thing on?
accord_minded's Avatar
The Wilbert - '04 Honda Accord EX
90 day: 37.54 mpg (US)
Phase I Complete: 18.8% Increase
Hi All-- It's great to be involved in this community!
So, I joined up a month or so ago after hearing about hypermiling from my brother. My situation is that I bought a 2004 Accord EX 4-cyl AT last December. Before that, we were a one-car family and since I had a 2.0 mile commute, I either walked or biked to work. Did that for 3 or 4 years and was feeling very virtuous.
Well, for many reasons I won't go in to, I am now faced with a 72 mile (EACH WAY) commute. So my commute just increased by, oh, 70 miles! On the good side is that it is almost all highway with little traffic. So, I don't have any stop-and-go stuff which would surely make it undoable. As it is, I can cover the 72 miles in either 65 minutes (without hypermiling) or 75 minutes (with hypermiling). With such a long commute I want to maximize my fuel efficiency. Also just want to do it with the car I have (2004 Accord) rather than get another car.
So I have a phased approach to improving fuel efficiency:
  • Phase I is just learn the hypermiling techniques. The only addition to the car is a SCII just so I could learn how it works and get used to it.
  • Phase II is to do the basic aero mods (air dam, lower grill block, upper grill block, passenger mirror delete, wheel covers, increase tire pressure). Also will get a vacuum gauge.
  • Phase III is a Kammback and maybe some other more advanced mechanical changes.
So, the results are in for Phase I: Hypermiling.
Baseline:
  • I have 2 baseline runs where I just drove normally with highway speeds (75-80 around here); liberal use of A/C; just driving as I used to drive. Tire pressure set to badge values 32F/30R.
  • After two fill-ups, my baseline average MPG is 28.47.
Hypermiling:
After completing the baselines, I started hypermiling.
  • What I'm doing: all the standard stuff, but no EOC (since my automatic transmission won't be happy with that). No A/C. Windows up. DWL, DWB, P&G, engine off while stopped, etc.
  • Tires still at 32F/30R.
  • After three fill-ups under hypermiling driving conditions, my average MPG is 33.82.
  • That's a 5.35 MPG increase or 18.8%!
Plus I can easily get to 500 miles on a tank which is really pleasing.
I'm prepping all the mods for Phase II all at once and then will install them all on the same day and on a mostly empty tank. Once the mods are on, I'll fill up and start Phase II testing which will be hypermiling and basic aeromods.
So rather than the incremental approach of: install one aeromod, measure results; install second aeromod, measure results; etc., I'm going to go with the all-at-once approach.
My goal is to be able to get to 40MPG and 600 miles on a tank. So, I'll need to increase fuel efficiency by another 15.5%. Doable?
