Old 08-19-2014, 12:31 PM   #23 (permalink)
SilverCrown9701
SilverCrown9701's Avatar
SilverCrown - '01 Toyota Camry LE
90 day: 35.32 mpg (US)
Originally Posted by dirtydave View Post
You just need to get a scangauge or other obd2 software find a road from 0-55 like a left turn onto the highway. And test it. I have found in my KIA most efficient is holding the thottle to TPS 25 and that's about half throttle. Shifting from 1> 3> 5 slowly going.
In my girlfriends 6 speed auto 2.5 I-5 2009 jetta its best to push it 3/4 of the way in getting to speed quickly and into 6th as soon as possible.
I would think most if not all automatic transmission cars are better off going slowly from a dead stop until 5MPH and then using 3/4 throttle.
I also think the manual transmission can accelerate more efficient ly. The difference in my KIA accelerating slowly and smooth vs quick heavy throttle and shifting at 2k rpms is nothing I have seen a difference at 1-4 mpg and during accelerating. Now in the jetta it is a much larger 4-8 mpg from a dead stop to 55 or 65 mph
I took a drive last night and accelerated up to 2500-3000 RPMs after every stop. I got up to 4th gear much more quickly than I did using the slower method, but at the end of the drive, my gas gauge needle dropped from half to almost a third.
Is this normal? Can the gas needle really be trusted or am I doing something wrong?
I usually use cruise control on the highway consistently because I can't keep a steady speed with my foot alone.
**NOTE: There are some slight elevations around my area as the ground slants lower going closer to the rivers I have to cross due to natural draining and erosion over the years.
The name "Camry" is an Anglicized phonetic transcription of the Japanese word kanmuri meaning "crown".
