Old 08-19-2014, 07:41 PM   #2 (permalink)
oil pan 4
I believe most are attempts to sell power factor correction gear to home owners.
With out proper survey and application of power factor correction capacitors, these capacitors will cause you to use more power.
Read up on power factor correction, some of the new meters are counting power consumed at lower power factor.
SwamiSalami (08-24-2014)
