Thread: VSS limit
Old 08-20-2014, 12:30 PM   #2 (permalink)
alexander.foti
Just had a longer ride today, after a quick tweak half way through, the mileage tracking is spot on with the clocks which is great!
I have to have my VSS delay set to 0ms otherwise it isnt accurate (as per my prev post).
I had a thought, my VSS pulse is 0-5v and is being generated by a hall effect sensor in the gearbox. I would be very suprised if my inability to detect above 78mph is due to signal noise, but instead due to the voltage?
If I can generate 0-12v instead of 0-5v from the clocks, does anyone know if it will get any better?
