Originally Posted by Ryland
I think it was around 59% energy transfer
I wonder if that is under acceleration or at constant speed, and fixed or variable pitch. A conventional drive will lose between 10-25% from friction and pumping (auto), so that's not too terrible.
Originally Posted by jamesqf
Of course the real question is why?
FAR 103, and not wanting to be limited to location.
A ducted fan or shrouded prop would help the stop and go, allow or a low prop (CG), and make shielding easy. With pitch control the drag losses might be comparable to a unshrouded/ducted, fixed prop at speed. Both of those add weight though. Maybe some emergency floats could offset that.
Did some research, oddly enough there is no law against driving with a prop, so long as your wheels don't kick up rocks.
There's also the possibility of hydrostatic, but that's heavy and inefficient too.
