Old 08-21-2014, 07:48 PM   #949 (permalink)
MPaulHolmes
PaulH
MPaulHolmes's Avatar
There is one more A/D. How would the brake be a variable signal? I've only heard of pressure switches, but not linear things, so more pressure gives a "more pressure" output. Are there 0-5v brake signal things? We would have to add a little RC filter, and connect to the unused A/D with a wire. Not a big deal.
The dang Index, QEA, QEB are hogging 3 of the A/Ds unfortunately. I had used a 40 pin thru hole dspic30f4011 because the tqfp or whatever they are called chips are hard for most people to solder.
I wonder if it would be mechanically possible for the brake to pull the throttle one way (regen territory), and the gas pedal to push it the other way.
EDIT: OK, I found a brake pressure switch. Basically a throttle. ground, 5v, and 0-5v as a function of PSI.
http://www.bimmerfest.com/forums/sho...d.php?t=592136
kits and boards
