Old 08-21-2014, 11:39 PM   #953 (permalink)
thingstodo
Ford Prefect - '18 Ford F150 XLT XTR
Tess - '22 Tesla Y LR
Originally Posted by MPaulHolmes View Post
Sure, if you use 1200v IGBTs, and 650v worth of batteries (or a boost converter on the front).
Hey, how should we do regen? In a perfect world, the throttle would be a wig wag, where you twist forward to command positive torque, twist backward to regen. But this is a crazy messed up world. So, what do we do instead? haha.
What component values change to adjust the boost you discussed earlier, with the battery + having an inductor in series to the controller?
Last edited by thingstodo; 08-22-2014 at 12:30 AM.. Reason: Remove comment on regen - solved already
