Old 08-22-2014, 01:38 PM   #10 (permalink)
jray3
Karmann Eclectric
jray3's Avatar
Odysseus - '00 Honda Odyssey
MR BEAN - '12 Mitsubishi i-MiEV SE
Karmann Eclectric - '71 VW Karmann Ghia Electric Conversion
BOB - '87 Ford 250 Lariat ext cab
Thanks All,
I commute in an EV, so the truck is only for projects that require grunt and it goes weeks without use. (If the truck is running, it's hauling!) So, I use a battery disconnect switch to kill the vampires, and like the simplicity of Bob's approach #2 for this job. Regarding starter voltage and amperage, it will spin faster on 16V, which means faster diesel starting, and will pull fewer amps on the same load, so I'm still comfortable trying the 16V series setup rather than 12V in parallel. Will post results.
2012 Mitsubishi i-MiEV, 112 MPGe
2000 Honda Odyssey
1987 F250 Diesel, 6.9L IDI, goes on anything greasy
1983 Grumman Kurbwatt, 170 kW "Gone Postal" twin
1983 Mazda RX-7 electric, 48 kW car show cruiser
1971 VW Karmann Ghia electric, 300 kW tire-smoker
1965 VW Karmann Ghia cabriolet, 1600cc
Have driven over 100,000 all-electric miles!
