Old 08-22-2014, 11:08 PM   #974 (permalink)
freebeard
I'm just trying to make an AC controller that people can adapt and change the code how they see fit for their own needs. I don't see the software as too bad...I didn't know what a maker space was.
This is me, making a conscientious effort to bring you up to speed. You can control how your ideas are disseminated, by simply affixing the appropriate logo to the work:
Originally Posted by http://creativecommons.org/licenses/
The Licenses
Attribution
CC BY
This license lets others distribute, remix, tweak, and build upon your work, even commercially, as long as they credit you for the original creation. This is the most accommodating of licenses offered. Recommended for maximum dissemination and use of licensed materials.
View License Deed | View Legal Code
Attribution-ShareAlike
CC BY-SA
This license lets others remix, tweak, and build upon your work even for commercial purposes, as long as they credit you and license their new creations under the identical terms. This license is often compared to “copyleft” free and open source software licenses. All new works based on yours will carry the same license, so any derivatives will also allow commercial use. This is the license used by Wikipedia, and is recommended for materials that would benefit from incorporating content from Wikipedia and similarly licensed projects.
Attribution-NoDerivs
CC BY-ND
This license allows for redistribution, commercial and non-commercial, as long as it is passed along unchanged and in whole, with credit to you.
Attribution-NonCommercial
CC BY-NC
This license lets others remix, tweak, and build upon your work non-commercially, and although their new works must also acknowledge you and be non-commercial, they don’t have to license their derivative works on the same terms.
Attribution-NonCommercial-ShareAlike
CC BY-NC-SA
This license lets others remix, tweak, and build upon your work non-commercially, as long as they credit you and license their new creations under the identical terms.
Attribution-NonCommercial-NoDerivs
CC BY-NC-ND
This license is the most restrictive of our six main licenses, only allowing others to download your works and share them with others as long as they credit you, but they can’t change them in any way or use them commercially.
The major advantage of open sourcing you hardware is you can benefit from others collaboration. Here's the founder of Local Motors given 20 minutes to explain how he's changing the way cars are made: Design-Build-Sell
https://www.youtube.com/watch?list=U...&v=GjuIM8xzYL4
A University will likely have better toys than an high school, but libraries are apparently where they will take off next. A big part of it would be the local people you'll meet.
Astro -- I was pulling your leg. The way reversing the ratchet works is it becomes push-to-set, so you can use the lever freely, but if you pull all the way up and push, the brake stays on. Sand rails use a cutting brake, which makes the two sides independent; think what drifters could do with that. And it's a proper lever between the seats, not a foot pedal.
MPaulHolmes (08-22-2014), thingstodo (08-23-2014)
