Thank you all for the input.
I will be locating the contactor in the battery area at the rear of the car.
I am glad nobody came up with a significant reason not to do this.
My batteries will be mounted under the vehicle where the petrol tank used to be so an easy and safe way to remove the entire battery pack is a must and mounting the contactors in the pack will make this possible.
