Old 08-23-2014, 10:19 AM   #5 (permalink)
Baltothewolf
Furry Furfag
Baltothewolf's Avatar
Winsight - '00 Honda Insight
Miaderp - '95 Mazda Miata
90 day: 28.53 mpg (US)
Originally Posted by hamsterpower View Post
You have the information already. It is in the upstream O2 sensor circuit. Either a bad connection or the sensor itself. You were able to drive N miles without a light because it takes three failed cycles (starts) to trip the MIL for an O2 sensor.
From countless threads on EM, use only a Honda original sensor as ALL others have incompatible resistance or fail again too quickly. But before you drop the money on a new sensor, follow the service manual test procedure to look for a faulty connection.
Also heard of people having success with this o2 sensor. I believe this is the exact one, even same company and everything that the dealership sells. NGK is what's used for stock plugs and wires so, yea.
NGK 24300 Oxygen Sensor - NGK/NTK Packaging:Amazon:Automotive
