Old 08-24-2014, 03:03 PM   #2 (permalink)
oil pan 4
1600rpm should be good for light load. Problem is these engines don't pump oil and coolant very fast at lower speeds which is bad when they are working hard.
The ford 9 inch has 3 bearings to support the pinion gear. The hypoid is further offset to give the gear teeth more contact. If you need it you need it. If you are going to even think about moving that much load you at least need a ring and pinion set up as strong as a ford 9 inch and full float axles wouldn't hurt.
