Old 08-24-2014, 05:45 PM   #3 (permalink)
E.Roy
fuel conserver
Civic - '99 Honda Civic EX
I'm disappointed that axle manufactures haven't invented a better way to disconnect front hubs from axles. So most trucks have parts spinning despite 4x4 not being needed, wearing them out. Stillsearching, aerodynamic drag can be a large difference between 2wd and 4x4 in 3/4 & 1 ton trucks if these have a solid front axle. Also transfer cases that hang down drag on the air.
Often, 2wd trucks have lower final drive ratios, say 3.55:1 vs 3.73 or 410. Also, they may be equipped with lighter, narrower and less aggressive tires from the factory.
'02 E-350 7.3 Diesel (Work Van)
'91.5 Cummins 4x4 (Old Blue)
'00 Jetta TDI 5spd
'22 Tundra TRD OR
'04 RX330
'05 Tacoma 4x4
