Old 08-25-2014, 05:54 AM   #44 (permalink)
Orangehonda
Originally Posted by Christ View Post
I'd chance a guess to say the i-Vtec engagement was designed to be seamless.. You could try a standard vacuum gauge (or tapping the MAP sensor's signal) to check for difference in vacuum that is controllable by modulating the throttle.
Wait for a defined change while you're not moving the throttle, then move it ever so slightly, see if you notice another more defined change in the signal/readout.
I don't know a whole lot about the R18 engine, other than they have a ~0.95 R/S ratio, by standard measurement, but the crank is offset from the bore centerline, helping the combustion stroke's efficiency.
They have an integrated header, plastic intake manifold... that's pretty much what I know about them so far. Until the local dealers get me more information, I'm afraid I can't contribute much more than that.
I am working on my engine and got some values from the fuel pump pressure, lub oil pressure, vacuum gauge reading and the OBD readings for this R18A engine.
For those interested,
My blog is at orangehonda.tumblr.com
Sorry, new users are not permitted to post links in their signatures.
