Old 08-27-2014, 04:10 AM   #2 (permalink)
AndrzejM
AndrzejM's Avatar
Berta - '97 BMW 318 tds Compact
90 day: 62.03 mpg (US)
Charlie - '07 Citroen C4 Grand Picasso Exclusive
90 day: 37.58 mpg (US)
Corsa - '05 Opel Corsa C
90 day: 53.22 mpg (US)
Mruczek - '03 Audi A2
90 day: 60.61 mpg (US)
Hi,
Cutting current to injectors can throw trouble codes - unfortunately. The best is to cut signal from crank position sensor, or cam position sensor. Depends on the car. It "tells" ECU that engine has stopped so ECU is cutting off the fuel and sparks.
It's best to find a wiring diagram for your car and then find the right place to cut the signal.
Gerhard Plattner: "The best attitude is to consider fuel saving a kind of sport. Everybody who has enough money for a strong car, can drive fast and hit the pedal. But saving fuel requires concentration, self-control and cleverness. It's a challenge with the nice effect of saving you money that you can use for other more important things."
The Following User Says Thank You to AndrzejM For This Useful Post:
jessebaker09 (08-28-2014)
