Old 08-27-2014, 06:21 PM   #8 (permalink)
aerohead
glass
Originally Posted by Weber95 View Post
The aero cap is later to come I've been on the lookout for old windows people are throwing out so I can snatch some glass an have it cut for a peep hole then I will be able to go full out on the aerocap. but if not 'Ill have to go with the half tonneau.
Any glazing material which goes down the road must be DOT rated.
Residential window glass might get you in trouble.
Keep your eye out for some sort of Plexiglass/Lexan for the peep hole,as they're both certified as replacement DOT glazing.
I've used discarded skylights which had a defect and just cut good material out.
If you put masking tape on the plastic,mark your lines and cut,you won't scratch the material.A sabre saw or bandsaw works great.
