Old 08-27-2014, 07:53 PM   #38 (permalink)
Insight for life
Insight for life's Avatar
05 Prius (wife's) - '05 Toyota Prius package 5
90 day: 44.32 mpg (US)
Citrus - '00 Honda Insight
Gen-1 Insights
90 day: 60.68 mpg (US)
EDIT: double-check. Are you sure I've got it wrong?
CALPOD was the originator of the engine-kill/FAS mod. I've seen it referred to as the "Calpod mod". But yes, I should have also used "Forced Auto Stop / FAS" in the description.
awh yes I realized that after I corrected you, I think we are both correct. I believe that the clutch switch is referred to as the Calpod switch, tho its true he was the originator of the kill switch for the insight.
