Old 08-28-2014, 02:45 AM   #4 (permalink)
AndrzejM
AndrzejM's Avatar
Berta - '97 BMW 318 tds Compact
90 day: 62.03 mpg (US)
Charlie - '07 Citroen C4 Grand Picasso Exclusive
90 day: 37.58 mpg (US)
Corsa - '05 Opel Corsa C
90 day: 53.22 mpg (US)
Mruczek - '03 Audi A2
90 day: 60.61 mpg (US)
Hi again,
I've found some information regarding Focus ECU wiring.
As you can see pins 30 and 55 are responsible for cam and crank position sensors. But you have different engine so probably your ECU and wiring will be different.
Anyway you can look for the sensors and try to disconnect them for a few times and you'll see if ECU will throw any errors.
Then you can thing of permanent solution.
It's better to put rely close to the sensor, because that's a sensor and any noise from long cables can cause trouble with the engine.
Good luck!
Gerhard Plattner: "The best attitude is to consider fuel saving a kind of sport. Everybody who has enough money for a strong car, can drive fast and hit the pedal. But saving fuel requires concentration, self-control and cleverness. It's a challenge with the nice effect of saving you money that you can use for other more important things."
The Following User Says Thank You to AndrzejM For This Useful Post:
jessebaker09 (08-28-2014)
