Old 08-28-2014, 10:22 AM   #11 (permalink)
mechman600
mechman600's Avatar
Fusion - '16 Ford Fusion Hybrid SE
You could probably lug any modern engine all day long above 1000 RPM and not hurt it.
Bucking and jerking happens at extremely low RPM, like after nearly stalling when dumping the clutch at <500 RPM. If you are constantly running in the <500 RPM range, something is wrong with you.
