You can try reclutching it. This is where you press the clutch and rev higher and try engaging it again.
For off road vehicles you have a low range and most of those can be modded for even more reduction. In the event you stall on a sticky situation many 4wd have a clutch over ride switch so you can start in gear and roll off.
Originally Posted by darcane
Downshift... ![Wink](/forum/images/smilies/wink.gif)
