I'd say no.
Most of the time I drive with the CVT maxed out in 'top gear', and then it ticks over at just under 1000 rpm per 30 mph, EGR valve open at 30%, engine load at 60% or so.
Pretty much maxed out efficiency wise.
I believe the G1 CVT revs higher per mph? And that was designed for a lighter car with smaller wheels.
Also, you'd need a G2 with engine trouble as a donor car if you don't want to waste money. That is a rare beast though.
There are so many cars around with much bigger engines than a G2 Insight that could benefit much more from having smaller engines. Why the Insight?
