Originally Posted by MetroMPG
Let me know when you're going to be around!
I think these lights are beyond simple polishing... I'm sure it'll improve them, but they're pretty pitted. I'll probably try polishing one first (since I already have stuff to do that). But I suspect I'll have to do the wet sanding method for best results.
I've never done either method but the one replacement light I have after an accident is cloudy. I'll have to check whether it is due to physical debris or just polishable.
Do you mind me sponging off you for the "already have the stuff" for anything that is non-consumable? We'll have to pick the weather appropriately though. We want to go from cloudy to clear, not variable cloudy, overcast, foggy, or ...
