Old 08-29-2014, 09:35 PM   #9 (permalink)
sheepdog 44
The engine will not like the extra 750-800lbs and added frontal area. The gen 1 is a slow poke, which is fine, but climbing hills and mountain passes with a Gen 2 body would give you a lot of anxiety. Not to mention the rolling resistance from non oem tires.
A turbo might help. I met a guy with one on a gen 1, and he said 5lbs of boost max is the safest.
I try to be helpful. I'm not an expert.
