Originally Posted by BamZipPow
You'll need to put something between the aero cap and the contact point on the cab or the aero cap will rub on the paint. A simple layer of tape will work fer now.
Good point!
How much give will yer aero cap have when the frame flexes from the bumps and jostles of the road? Something to consider if you don't want truck to rip the aero cap from the attachment points when the bed compresses into the cab.
Hm... I mistated that I had removed the gap altogether. It actually is still there, but it's about 1/4 of an inch (6.4 mm) instead of... many inches. The truck seems to like the decreased gap, too. This was to address the bed flexing issue, as well as the paint rubbing issue. In the sunlight, the gap itself can still be seen.
The FoamulaR skin covers the gap, with no reinforcements. When I go to skin the thing, finally, I might expand the gap some, and seal it with some sort of flexible door seal.
I really need to get that MPGuino installed.
