Old 08-30-2014, 08:06 PM   #11 (permalink)
oil pan 4
Problem with a turbo charger on a gasoline engine is its always on. Always hurting fuel economy.
Now if it were a diesel, put a turbo charger on and see at least a 10% gain.
You can use water methanol as fuel for your wet shot, but then you have and extra fuel system to drag around.
Adding nitrous would be much easier than adding an electric motor.
