Old 08-30-2014, 09:55 PM   #4 (permalink)
cRiPpLe_rOoStEr
What exactly are you considering to do? An all-electric conversion or some sort of hybrid setup?
Originally Posted by Cobb View Post
The problem was it uses 650 volts vs the 288 volts that the prius uses and in order to get that voltage you need a lot of damn batteries or some type of voltage doubler or tripler.
Some hybrid trucks and buses have been fitted with a 650-volt setup nowadays, not impossible to source parts from.
