Old 08-30-2014, 11:46 PM   #26 (permalink)
XYZ
Originally Posted by jamesqf View Post
Where on earth did you get the idea that newer engines (or cars, FTM) don't last as long as older ones? Back in the "good ol' days" it wasn't at all unusual to do valve jobs, replace rings, head gaskets, main bearings, seals, and so on before the car hit 100K miles - and adding a quart of oil every couple of thousand miles was normal. And then there was chassis lubrication: anyone else remember grease fittings?
Back in the day - say 50 years ago - a new car was pretty much junk in 5-10 years. Now I expect my 2000 Honda and 1988 Toyota to last for at least another decade with only minor maintenance & repair.
I agree with you in that cars can and often do last longer now. The ones that were made in the '80s and 90's were often well designed and usually not overly complicated to work on.
But the things that go wrong nowadays with a car are often no longer simple to fix. Crappy electronics, codes being set that are hard to resolve, and bad sensors come to mind. When the cost of repair exceeds the cost of keeping any vehicle, it often gets sold as a used PITA with problems that are not easily resolved.
