Old 08-31-2014, 02:01 PM   #44 (permalink)
pgfpro
In Lean Burn Mode
pgfpro's Avatar
MisFit Talon - '91 Eagle Talon TSi
Team Turbocharged!
90 day: 63.95 mpg (US)
Warlock - '71 Chevy Camaro
Fe Eclipse - '97 Mitsubishi Eclipse GS
Update:
Pick up a new turbo to test with my monster BW S475.
New high pressure turbo:
DSM 68HTA
Compressor wheel - 68HTA
Flow rating - 51LB per minute
CW Measurements - 51.2MM Inducer / 68MM Exducer
TW Measurements - 60.8MM Inducer / 54MM Exducer
Compressor Housing - 16G TD05H
Turbine Housing - FP 8CM
CHRA - FP Journal Bearing
Pic
Low Pressure turbo:
BW S475
Compressor wheel - 75 mm ETT
Flow rating - 100LB per minute
CW Measurements - 75MM Inducer / 100MM Exducer
TW Measurements - 96MM Inducer / 88MM Exducer
Compressor Housing BW S400SX4
Frame T6 with a 1.32 A/R
CHRA - BW Journal Bearing
Pic
This combination has be tested and proven with a fellow DSM Talon friend that has gone high 7's at 180mph in the 1/4. He is one of the pioneers in gasoline turbo compound systems.
Here are some data-logs from his runs showing great back pressure numbers.
Back pressure log
Awesome engine delt p numbers as the gates open to bypass around the high pressure turbo!!!
For me HP performance will always be in my blood so the more I can make the better, but I think this combination will help also with back pressure issues at light load and help with FE.
Pressure Gradient Force
The Positive Side of the Number Line
The Following User Says Thank You to pgfpro For This Useful Post:
jedi_sol (09-01-2014)
