Old 08-31-2014, 02:18 PM   #28 (permalink)
oil pan 4
Originally Posted by Gasoline Fumes View Post
I think the ideal way to go is with a pump and external heat exchanger. Trans/diff pumps exist, but they aren't cheap. There must be a cheaper alternative out there.
Pumps - Mocal Differential Cooler Pump
http://www.summitracing.com/search/p...l-cooler-pumps
A standard chemical rated surflow diaphragm pump would likely work just as well.
