Originally Posted by XYZ
But the things that go wrong nowadays with a car are often no longer simple to fix. Crappy electronics, codes being set that are hard to resolve, and bad sensors come to mind.
Define "simple". I'll agree that current technology is often
different, but I'll take tracking down a code or sensor problem over e.g. trying to balance an SU carb setup, tune a conventional carb, file and gap distributor points, etc.
Then you have a whole spectrum of problems that just don't happen with modern engines, like tuning. Nor do I know that trying to fix/replace an electric power steering motor is any worse than doing the same with a hydraulic one - and at least you don't have to regularly check & replace the power steering belt. As for variable geometry turbos, CVT transmissions, and the like, I have a simple fix: I just don't buy cars that have these things. Any new technology needs a few iterations to work out the bugs.
