Originally Posted by Cobb
Rev match, blah, hahahahahahaha. ![Big Grin](/forum/images/smilies/biggrin.gif) Ive never done that in any vehicles Ive owned unless the clutch cable was busted. Then Id start in gear and feel my way to the next gear.
For down shifting I just work the clutch and brake, dumping the clutch as the engine idles and watch it fly up to 3, 4, 5 grand as I work my way to a stop.
Clutches are designed to wear and be replaced, like brakes.
The wear is not so bad but remember the drive efficiency from wheels to engine here is under 50% (50% at the clutch because it's slipping, plus transmission losses). I'm pretty sure you'd save more fuel if you used the gas pedal to rev the engine up.
Plus, the jolt is probably bad for the transmission.
