Originally Posted by Old Mechanic
I don't see anything wrong with your current technique and considering the cost of a transmission repair, if you are not comfortable with coasting in neutral then don't do it.
I have been doing it for a long time with no problems, but then I could probably get mine repaired fairly cheap.
regards
Mech
Awesome!
So far I'm at 413 miles and my gas needle is halfway empty. If I used cruise control, it would be around the 285-300 mile mark on the odometer. It has an 18.5 gallon tank.
