Old 09-01-2014, 11:28 PM   #6 (permalink)
XYZ
Originally Posted by Old Mechanic View Post
I don't see anything wrong with your current technique and considering the cost of a transmission repair, if you are not comfortable with coasting in neutral then don't do it.
I have been doing it for a long time with no problems, but then I could probably get mine repaired fairly cheap.
regards
Mech
Nothing beats hearing an honest response here.
I'll add what I know: You can coast in neutral in virtually any car that has an automatic transmission. Any detriment to the transmission will only occur when shifting back into drive. However if you coast to a stop or a near stop (10 MPH or less) before shifting back into Drive, it won't harm your transmission. As far as I know this works with all automatics, no matter how old the vehicle is.
