Old 09-02-2014, 02:32 AM   #32 (permalink)
Gasoline Fumes
Too many cars
Gasoline Fumes's Avatar
CRXFi - '88 Honda CRX XFi
Insight 256 - '00 Honda Insight
Gen-1 Insights
Insight 5342 (no IMA) - '00 Honda Insight
Gen-1 Insights
90 day: 66.3 mpg (US)
Why would you want to use an additional electric pump (and thus another load on the engine), when you could just use the coolant pump that is already on the car?
The reason I suggest pumping the trans fluid to a heat exchanger is because I don't think you'll find enough usable surface area on a trans to get a decent heat transfer.
2000 Honda Insight
2000 Honda Insight
2000 Honda Insight
2006 Honda Insight (parts car)
1988 Honda CRXFi
1994 Geo Metro
The Following User Says Thank You to Gasoline Fumes For This Useful Post:
Daox (09-02-2014)
