Old 09-02-2014, 04:11 PM   #1074 (permalink)
e*clipse
Permanent Apprentice
Paul, just wondering - I can be no help here with the ACIM magic.
Did my explanation make any sense regarding the resolvers? Would you have any interest in using the MGR as a test subject?
If so, I could help with resolver code. I could also lend you one. (either a resolver or the whole MGR) I mean, the only difference between a system that uses an encoder and one that uses a resolver may be a bit of code and a small daughter board.
- Thoughts?
- E*clipse
The Following User Says Thank You to e*clipse For This Useful Post:
MPaulHolmes (09-02-2014)
