Originally Posted by jeff88
Is there a way to measure how fast the pump is currently spinning... maybe with an adjustable strobe light? At that point you could size a motor properly.
It's simply a ratio of the circumference of the drive pulley and the water pump pulley. The speed varies with RPMs, idle would minimum and red line max.
