Old 09-02-2014, 09:00 PM   #1080 (permalink)
MPaulHolmes
PaulH
MPaulHolmes's Avatar
Having 2 waves, centered about 2.5v, 90 degrees out of phase would solve the problem completely for me. If you want to focus on that, it would be all I need. They don't even need to be perfect sine and cos waves. Just garbage such that they are the same waves every time, and (sin(theta1),cos(theta1)) == (sin(theta2),cos(theta2)) if and only if theta1 == theta2. Then we could do up a "asin" lookup table which would reduce the angle to 2 possibilities, and then look at cos(), and go with the angle that's closest to the cos() value. badabing badaboom. There's plenty of memory on the dspic, so a big lookup table for lots of resolution wouldn't be a problem. It would be one array access, and then an if..then, and we'd know the angle. That would be fast at 30MIPS.
kits and boards
The Following User Says Thank You to MPaulHolmes For This Useful Post:
e*clipse (09-02-2014)
