Problem with a turbo charger on a gasoline engine is its always on. Always hurting fuel economy.
Now if it were a diesel, put a turbo charger on and see at least a 10% gain.
You can use water methanol as fuel for your wet shot, but then you have and extra fuel system to drag around.
Adding nitrous would be much easier than adding an electric motor.
You can either disconnect the supercharger with an electric clutch, like air conditioning.
Some centrifugal superchargers and most turbo compressor stages allow the engine to breathe thru the compressor wheel even if it is not moving.
