Old 09-02-2014, 11:20 PM   #43 (permalink)
e*clipse
Permanent Apprentice
Cool
Exactlly That's what I'm doing with the Eclipse. That, and the low Cd is why I'm using an Eclipse as the base for my conversion. I can start out with a real easy 4wd, then upgrade to more power and an electronic differential in the front without much effort. If I can STILL stay out of trouble, AWD with 200kW and electronic differentials is available.
Actually, the 4X4 was done very nicely some years ago with a Subaru. I think the guys who did the conversion put those Siemans AC motors front & back. Apparently the rally racing guys control the power balance between front & rear on the fly. Somehow the transfer case allows this to be adjusted by a knob on the fly.
I was mostly addressing your situation with a rwd BMW.
Originally Posted by 4x4EV View Post
Why both in the back end? Put one for fwd in the front and rwd one in the back with the gears. Even weight close to direct drive awd or partial 4wd /2wd and shut off one or the other to conserve power
The Following User Says Thank You to e*clipse For This Useful Post:
4x4EV (09-02-2014)
