Old 09-03-2014, 03:26 PM   #23 (permalink)
oil pan 4
Here is one for you:
http://ecomodder.com/forum/showthrea...tml#post297056
"Super Chevy did a water pump dyno test and didn't even report results from below 3000rpm, because they couldn't measure it."
So turn the coolant pump at around 2000RPM with crank shaft torque or electrical power and you should be good to go.
