Old 09-03-2014, 10:20 PM   #26 (permalink)
BobS
diesel doer
Daox
Since sqidd has a car electronic pump controller, perhaps you could get his type of controller at a U Pick Um. Might I suggest that you can arrange a large wattage resistor parallel to the controller with a DPDT switch to select the resistor if there is failure of the controller.
