Old 09-04-2014, 01:42 PM   #44 (permalink)
t vago
MPGuino Supporter
t vago's Avatar
iNXS - '10 Opel Zafira 111 Anniversary
Suzi - '02 Suzuki Swift GL
I didn't have a problem until HHOLugNut started posting his nonsense into my thread
Originally Posted by RustyLugNut View Post
That in itself has value.
So you have done some work that correlates what people have known for some time. Assuming your data is good. I am not saying it isn't. I am saying it can be suspect. And I have good reason to suspect it.
I suspect that you do not really have good reason to engage in a thoughtful discussion. If you were, you would not have compared apples to steaks, in order to sneer at my results to date.
I suspect most of the HHO claims. But, I have inspected setups that defy reason. I suspect mileage claims on engines that fool with the modern OBD II systems. Often, the mileage gain is nothing more than the system reaction to changes in the sensor parameters and not so much the actual mod.
And I suspect any engine mod that requires extra generated work in order to gain a small amount of improvement. Same goes with mods that require working with dangerous/flammable/explosive additions.
Do you have a data log of your EGR flow rate with correlation to intake pressure and throttle position? At what RPM?
Nope, for the simple reason that I did not at the time feel like spending several hundred dollars in gathering the necessary logging equipment to log OBD parameters. Even a smartphone with Torque and that nifty little Bluetooth adapter, you will have to admit, costs several hundred dollars. I simply did not see the need to expend money for said smartphone/Torque/OBD adapter solely for the purpose of logging OBD parameters, when my goal was to SAVE money by saving gas.
I did, however, decide that the best way to measure fuel consumption changes was by installing something that actually and directly measures fuel consumption, which is why the Karen-mobile now has an MPGuino installed. It's very likely the world's only LX car that has such a device installed. However, I can see that you a) would not understand that, and b) would likely just sneer at my fuel logs anyhow.
However, since I am now (reluctantly) part of the smartphone set, and I have in fact bought a Bluetooth adapter for use with Torque Pro (which I have installed), and I have in fact also installed the Track Recorder addon, I will be able to generate log csv files, and generate subtitled drives that will have this information, and will posted online for all the world to see.
What is your O2 sensor output telling you?
I am curious as to how my O2 sensors are supposed to detect more inert gas being fed into the engine. Especially as they are of the OEM narrowband variety, which will pretty much only tell whether an engine is running too rich or too lean.
Perhaps you meant "long term fuel trim," instead. Who knows?
I have seen HHO proponents put a few cents worth of resistors and diodes on the O2 sensor output and run their engines lean of 18:1 AFR with no codes or apparent operating problems. It allows them to claim a 20% or so savings. Of course, with them, they claim it is all due to the HHO from their mason jar electrolyzer. But, why not? It works for you, it works for them. No harm done.
And then you go and smear me further by lumping in my work with that of these other HHO charlatans. Do you even understand how my modification works? No, you don't, do you?
Since it looks like you think your 7.7% gain is good, your work is done!
I like how you sneer at a 7.7% increase in fuel economy. That's better than using a grille block, better than using aero wheel covers, better than using a warm air intake, and better than using an underpan. The only thing that does better than 7.7% is an aero bedcap.
However, since you don't think that 7.7% is good, especially for an engine mod (!), I'll leave it to your oh-so-much-smarter self to enlighten us knuckledraggers as to what constitutes a "worthy" mod.
You have hit the ceiling for this mod. Unless you think there is more. At that point, this needs to go in the Corral.
So sayeth HHOLugNut.
And you want me to leave? I have provided you with better discussion than what you have posted in the Corral in subject matter you have no understanding in and yet you post empty and derogatory entries. Your posts are there for all to see. Unless you want to go back and delete them. They are numerous. Now you feel uncomfortable because I and others actually understand the subject and we are asking you questions with substance?
Deliberately mischaracterizing my work, and using unattainable goals to sneer at my results, does not equate to "understanding the subject."
Why not drag up some of my posts in which you claim I have no understanding, and show them (or their links) here? Let's go beyond your unsubstantiated smearing.
Ok, I'll let you be. I'll leave you to your comfortable cocoon.
Still waiting...
By the way, I also own a 2005 Dodge Magnum R/T with the 5.7L Hemi and the NAG1 5 speed auto-stick. I take advantage of the 8-6-4 capabilities of the engine and regularly get 26-27 mpg, tank-to-tank on freeway trips at 61 mph or less, depending.
Big deal. I can do the same with my 3.5L Magnum with a 42LE, travelling at an average speed of 75 MPH down the highway. Once I get my 2.87 pumpkin installed, I'll likely see even better. And all that's WITHOUT using HHO or any of that other Unicorn Corral nonsense.
The engine reverts to more cylinders at speeds over 62 mph. It seems to be torque needs that cause the break-over.
It's Chrysler attempting to make MDS (not the same at all as 8-6-4, BTW) appeal to every possible Magnum buyer.
By feeding HHO gas from an industrial electrolyzer into the 4 firing cylinders, I am able to see an increase in torque with a reduction in injector pulse width (fuel trim) along with the ability to stay in 4 cylinder mode up to 65 mph and an increase in fuel economy of . . .
And here we come to the heart of the matter - it's not that I can see a 7.7% increase in fuel economy, using gas pumped from the same pump at the same gas station, under reasonably similar travel conditions and driving similar distances. It's that people here sneer at anything HHO, including your outlandish claims, leading you to attack anyone else who has something that actually works!
Where is your own build thread?
Oh but this is your thread! I will post in another build thread. And I trust you will stay out of it? Right?
Question is - why did you not do this already? Why post your HHO nonsense in my thread?
