Originally Posted by California98Civic
Because the ultragauge is dependent on the sensors and there is no FE sensor. So therefore the 999.99 mpg number is a UG calculated guess. The sensor is directly reading the exhaust and reporting out voltage according to what it finds. Given how many times the engine turns in a second at 1500 or 2000 rpms, I can't imagine residual fuel would last more than 1 or 2 seconds. But this can go on continually over 10 seconds, and not at 0.015, but at numbers like 0.6 and such. There's no way that at a 0.6 O2 voltage reading from the sensor the FE could actually be 999.99 mpg, is there? What do you think?
I always coast in gear rather than in neutral because my Camry has DFCO. My UltraGauge reads 999.9 MPG when I release the throttle.
I can say for myself that it does save gasoline, I just averaged over 37 MPG on my last trip cycle from lots of in gear coasting and other techniques in my Camry
I hope this helps!
-SC
