Can Propane and Gas be combined?
Like the title asks, using a flow meter, can we use propane to mix in with the air like so many want to see with HHO?
Seems a bit easier, the expensive part is buying a digital flow meter and then dialing it in to the proper rate of flow. That is of course if this is even possible.
Experts ...
Thx NoCO2; "The biggest FE mod you can make is to adjust the nut behind the wheel"
I am a precisional instrument of speed and aeromatics
If your knees bent in the opposite direction......what would a chair look like???
