Old 09-05-2014, 12:09 AM   #43 (permalink)
oil pan 4
Small engines don't typically use double acting thermostats. My diesel has one.
Even small block chevys do not have them.
Originally Posted by sqidd View Post
So you want to run the water around before you start the motor? Novel idea. Pre-heat the block, then circulate the water to the trans and warm that up too. Then start the car. I like that.
Yeah.
http://ecomodder.com/forum/showthrea...mer-23893.html
Everything I have read recommends not starting diesel engines below 20'C and 50'C is recommended.
